Stock weight bug.. unknown ratios,, Probably stock.. several raptor grinds available... probably a total mismatch of parts.. probably a rather bad performance.. without knowing ALL, or at least MOST of the specs.. I would say more likely 14, 15-16 seconds.. and probably NOT a fun car.. But I could be wrong.. It has been said many times.. IT IS THE COMBINATION that makes a car quick/ fast. you can not take a bunch of good parts, and combine them with a heavy car and big port heads and expect anything much better than less than optimum performance. A stock stroke engine with big ports and stock(wide ratio) and or ,God forbid, Hiway flyer gears will be a TOTAL pig.. Why have you chosen THAT combination of parts? Because they were a good deal, or was just readily available? If you really want to make your combo work, find out at the minimum, what cam, gears etc you have. We will try to help. If you still have not built the motor, i would suggest you strongly consider finding out what you have. And think about a stroker ...A full weight 74 sedan is gonna be around 2-2100 pounds.. Even with 2 stroke onboard...A cam with 9k capability is gonna suck at that weight unless you run a box with maybe 4.86 close ratios...trim the weight, build an engine that makes good useable power to 6-6500 or so, with a cam of around 255-260 at .050, and gear accordingly. 9,000 RPM is stupid for the street...You will just break ****.. read up on the many posts , and then come back with more info...being charitable, and working with the possibilty you have all the parts and pices in place and about 2000 pounds car and driver.. A GOOD combo with the right cam, heads, carbs etc could produce 150 or so HP.. It's been done.. i suppose a low 13 would be possible.. But highly doubtful with stockish gears and that weight. READ , RE- READ. then ask. good luck.
