Just looking for some real world advice on my engine build. I'm in the process of building a 2276cc turbo efi engine for the street.
I have the new AS41 case, machined for the 94mm barrels , decked and clearenced etc.
94mm forged piston set.
82mm forged crank.
5.4 H beam rods.
I would like to know what camshaft, cylinder heads, turbo, to potentially run,
I want to run a single throttle body with individual injectors for each cylinder similar to the DubShop kit.
I will run a barrel style water/air intercooler. The turbo will be an under the apron setup.
Your advice is very welcomed as I have only built stroked N/A engines so far.
82mm forged crank.
5.4 H beam rods.
