40 DCOE Weber Jetting
So I have a 2332 turbo motor with a 40 dcoe side draft that came out of a sandrail and I stuck in my bug. I just started to race it and was wondering what a good starting point was for jets. Main, air, emulsion tubes. The car is plumbed with 3/8 hard line -6 fitting off the tank to a holley red pump and has a boost referenced holley regulator feeding the car. After doing some reading I know the carb is a little small to make any real power but it is a starting point in racing until I step up to a holley or efi.
Gentlemen,
I had a customer with a Turbo sand rail that had a Turbocharged 2110 with a 40DCOE. To make it really short he had this buggy at some big name shops. (I got to drive it) The buggy was good out of the hole but when the boost started to kick in the engine would lay over. If you feather the throttle, it would start to pull. If you stayed in it, Engine would start to ping (YIKES).
Anyway, the set up (I did not build this motor I got to inspect it)
2110
90.5X82, Engle 100, Stock rockers, on solid shafts, CB Performance 042 heads chamber 51cc; un touched 40X35.5, compression - 9.67:1 .060in Deck height. 40 DCOE draw through, holley blue pump, rising rate fuel pressure regulator 12-803 tapped for turbo. Idle fuel pressure 2.5psi. Plugs W8AC Ignition – 009 distributor with MSD 6. Timing limited to 22° BTDC
Jetting as received:
34mm venturies, Idle 55, Main gas 150, air correction 200, emulsion tube F11, needle and seat - 200
What I did:
Reset the compression, lowered deck height to .180”in. made it 7.3:1
Left the fuel system alone
40DCOE – Drilled the float well and main jet passages. Tapered the emulsion tubes, enlarged the main fuel openings on the emulsion tubes. Installed 250 needle and seat. Checked the float drop and readjusted (Wanted the float to drop as low as it could in the float bowl)
Jetting
34mm venturies, Idle 70, main gas 170, air correction 180, emulsion tube F2, needle and seat 250
I trashed the MSD 6, kept the 009 and used the Comp-U-Fire ignition WAYYY Better. Timing still 22° BTDC. Kept the W8AC plugs, Tried W7AC those would cause a stumble if just putting around the dunes.
14psi boost premium pump gas (No race fuel)
Results? - Well the customer sent me a video of him beating his Dad’s LSx powered buggy up competition hill. I have his picture with a HUGE grin on top of Competition Hill Glamis CA.
Oh the gentlemen staggering the emulsion tubes, the F11 and F7 is on the right track.
Regards,
Randy
Any questions about the setup, E-mail or PM
Metricelectric at s b c global dot net
