Is it possible or just waisting time with broken parts?
Type 1 then its going to break, Type 2 002 or 091 will last along time with upgraded internalsIs it possible or just waisting time with broken parts?
whoops I didnt see where he wrote it would have 350hp?You would be surprised how long a good type one trans will last at the 350 HP level if you slip the clutch enough off the line. In 14 years of running my turbo car I only broke a couple of transmissions, with regular servicing I almost always caught parts ready to break.
USE? It's a ball-park assumption for what many folks are running.whoops I didnt see where he wrote it would have 350hp?
I did talk to Mike a little bit and he is for going to a swing axle and ditching the IRS. The engine is N/A with nitrous with total power 300-350. Mike was concerned that for the expense for an IRS it still wouldn't be as reliable as a cheaper S/Axle. Mainly looking for someone running an IRS and what they did to keep it alive.USE? It's a ball-park assumption for what many folks are running.
Contact Mike Gagnier: https://www.facebook.com/PEPVWS?ref=br_tf
He builds and services a lot of transmissions for the USE, ASA, SEVWA and ECPRA racers. I've installed several of his transaxles and am always impressed with his work, communication, and relationship he maintains with the racers and his customers. He can point you in the right direction!
Berg or similar intermidiate housing conversion to use type 1 gears, but keep the bigger 002 R&P,with the correct nosecone this keeps the shift rod in stock position, then either type 2/4/944 or 930 cvs and axles, then thing or aftermarket stub axlesSo knowing just a little about type 2 boxes what's the norm for stuffing one in a bug. 002 or 091? Shifter above the tunnel or different nose cone? Stick with type 2 cv's and use a thing stub axle or?? Gear ratios-- what R&P and are close gears avail?
Please enlighten me O great UAC members.![]()
Call Rancho Performance Transmissions in California and ask for Sam.So knowing just a little about type 2 boxes what's the norm for stuffing one in a bug. 002 or 091? Shifter above the tunnel or different nose cone? Stick with type 2 cv's and use a thing stub axle or?? Gear ratios-- what R&P and are close gears avail?
Well it used to be you would go out and get an 091 and a 002. Pull the pinion out of both and send it to DK machine and have the pinion head from the 4.57 out of the 091 put on the 002 main shaft. Toss the 002 ring gear and use the 091 4.57 ring gear. You would use the 091 case unless you had the 5 rib pyramid case for your 002 donor. If you used the 091 case you put the 002 bellhousing on and used the 002 input shaft. Then you had your choice of all the type1 and 002 aftermarket gears for 1-4. And the berg or erco housing that changes it over to type 1 shift components is a must for serious drag racing. Now days you buy an aftermarket 002 ring and pinion from weddle and skip the 091 stuff altogether. But either way you get really what ever type1 or 002 gears you want by using the 002 pinion shaft so you have a lot of gear ratio options.So knowing just a little about type 2 boxes what's the norm for stuffing one in a bug. 002 or 091? Shifter above the tunnel or different nose cone? Stick with type 2 cv's and use a thing stub axle or?? Gear ratios-- what R&P and are close gears avail?
