Need more info.Help! I want to put a bus in a bug. Any tips, advice, details needed.
Swing to swing it will fit.Fiatdude, I'm kinda confused. I've been told that the shift rod would be above the tunnel, but the bus transaxle fit right thru the hole and into the shift linkage. Problem is it's too long as you showed.
