1 - 3 of 3 Posts
good mornin to all,gonna start buying bottom end stuff, is there and cons to using a cb crank with scat h-beams with 3/8 rod bolts. or should i go with either all cb or all scat. i'm partial to using 3/8 bolts other than 5/16. cb rods only come with 5/16.... 2332, steve timms weekend warrior heads, slr x316 cam , street strip use. thanks for any imputs.
Shouldn't be any problem mixing and matching. That being said, We still use the 5/16 bolts (ARP 2000) in a aprox 250 HP 2332 with no failures yet. We do check rod bearings about every 24 or so passes though.
Thanks kev, I dont think I"ll be hitting nowhere near 250. So I think I"ll go the cb route., with 5/16 bolts.
1 - 3 of 3 Posts
