1 - 14 of 14 Posts
Is there any website (or book to buy) explaining the tuning of Demon carburetors on turbo applications ?
Base jettings, accel pumps CCing, secondary cam shafts settings, power valve sizing, etc . . ?
Thanks .
:laugh:.... On my vacuum Demon 750...What helped a ton was a 50cc pump and the largest damn accelerator pump cam.. Also the heavest spring in the vacuum pod for the secondaries. I have also removed and plugged the power valve and have jetted way up from stock jetting....I may still be too lean too...
I am 85 primary and 95 secondary with a plugged off power valve.
Ann may be able to tell you if there is some sort of guide.
There's some information on the Barry Grant website that may or may not help you. http://www.barrygrant.com/demon/default.aspx and they do have technical support that you can contact personally.
All of the carburetors come with what BG feels is a good baseline straight out of the box & it works if you have the correct carburetor for your engine IF that engine is a common / widely used application. The majority of these carburetors are used on 6 & 8 cylinder engines so they are the tuning target audience. The information & tuning tips they provide is good, but you will most likely need to tweak & filter the advice to your specific needs for your engine. With that in mind, your best guidance & reference points will most likely be from people who have experience with using the Demon in the air-cooled turbo sector. Believe it or not, there's not a lot of us out there. :no:
That said, which Demon do you have & what are your specific questions?
In fact, i put my EFI in the trash box :nerdystraight: and swapped to a Demon setup .
750 speed demon, mechanical secondaries, i've just machined the base plate to make the power vale boost sensitive . Jetting seems good, i'm at 11.6 AFR @ 20psi of boost (i log both AFR&Boost with my small innovate LM1) , jetting is 79 prim / 86 sec . accel pump cam is the pink one . The power valve & accel pumps are those "out the box" ( carb # is 1402010) . I found this setup not very smooth, always have to rev the engine to feel "power" under the foot . What i'd like is a fine tune to have something smoother . engine is a 2387cc, T0x ? (T04 i think) Comp Turbo From marty with 40x50 910 heads , drag use only .
Carbs are new to me so a tuning guide will be very helpful . :grinwink:
I like how it looks to have air bleed info.. Mine are not changeable but I know I can drill mine out, tap the holes and make them changeable if needed.
Discussion Starter #8
Brian , i see you've plugged the power valve and jetted bigger . What are differences between plugged & boost referenced power valves ? Why plugging it ? In my mind, referencing the power valve affects only boost "range" Vs plugging it , you're always "richer" ? I know RLR do it on some holley setups but it's difficult to understand in my small head :nerdystraight:
I cannot explain this....For the reason I don't know!! I do not have a handle on my tune.
When I boost referenced the power valve the engine responded much better. I had an issue when I rolled the throttle on too fast it would bog. Boost referencing the valve helped eliminate that. I was jetting with an LM-1 and my numbers looked good 12.5 cruising and 11.5 under boost. But I still had a hesitation if I rolled the throttle on too fast.
I removed the valve one day to try it out..Also because I was affraid if I went to start the car and if it had a small back fire it would damage the valve.
So with the valve removed and with the jetting close..It is very drivable. No hesitation when I roll the throttle on fast, it will cruise in traffic or on the freeway.
But I have made a few other changes too.. remember I have a vacuum secondary carb.. What helped the most was going to a larger accelerator pump and using a heavy spring the keep the secondaries from opening too soon. Also going up on the jetting....I am unsure what my A/F is right now but I keep going up in jet sizes and it still seems to runs well...It keeps taking the fuel and loving it.
I now have some soot in the exhaust pipe but the waste gate dump tube is very light gray (race fuel) and no soot can be found. I am going to go up two sizes on the secondary side today and see what the car does as far as MPH in the 1/4.
I don't think this will help you at all but Its all I could come up with for a response...
Discussion Starter #10
I also have hesitation on fast throttle action . I'm gonna try a smaller value of vacuum on the PV (6.5 now) , if it changes nothing i'm gonna plug it like you .
Is this setup on your 20v water cooled ? Did you machine the choke tower ?
The pink accelerator pump cam you are running is the smallest one....I am running the yellow with a 50 cc pump... You have 2 accelerator pumps so things will be different, But for me more accel pump and the large pump cam took care of the hesitaion on fast action throttle.
And no I have not removed the choke tower yet....It going to take some hours to lopp it off then hand grind it all nice and smooth to match. I want to make my air bleads changable too.
Discussion Starter #13
Thank you both of you . I'm gonna buy a pump cam kit and larger accel pump diaphragms . When i will receive the book, i will also make the air bleeds modification i think .
Thanks .
1 - 14 of 14 Posts
