I have an 82 mm crank from DPR. I have a gene berg flywheel that uses the o ring. Do I need to have my crank machined for the o ring or can I make it work without doing so. I notice on a crank that for the o ring there is a slight chamfer on it and was curious if this would affect the seal, end play etc.
Any information is appreciated.
Thanks
The crank has a slight chamfer at the end for the O ring to sit on, the two pieces you have should just fit straight together without any mods needed
If the crank has a taper on the end its been set up for a wedgemate
Will
