1 - 5 of 5 Posts
86x94 with 5.7's combo, fk89, ida's and 11 or 12:1, debating 910's or ce's in a full weight car. not a daily car only one or two days a week and most likely eves after work.
cb's full out comp elims = 2000$
910"s im considering 2500$ ported and polished
trans type one 388 rp
sugg gear ratios ? help
car is only meant to show non vw's my backside
wayne aka chiller fixer
go with the comp elims. they are plenty for your combo especially since you will be doing a little street driving. with the auto craft you will probably have to launch at 9 grand to keep it from falling on its face. gear boxes hate that stuff. if you go to wallace racing calculators there a calc. on there that will tell you what rpm is needed to flow your head based on head cfm and cylinder volume or something like that. that site will suck you in you will be on there for 45 mins before ya know it. good luck
Read the "Building A 10-Second 2332" in the April and May issues of HVW. Use the Pro-Gas wedge ports for about $1,000 and put that money you'll save towards a Bus trans. With your 86 stroke you should be able to develop close to 240HP with around 12 to 12.5 to 1 compression.
1 - 5 of 5 Posts
