I Recently went with Jamar front brakes (Wide 5) and have been having problems ever since.
Had to have the front hats machined .070 so they would fit but got them working.
NOT Happy that I had to modify a brand new product to get it to fit but that seems to be the case with some aftermarket VW parts.
The single piston calipers in the front release just fine upon releasing the brake.
The rears are another story altogether.
The rear Jamar 4 piston calipers were Sticking, (Dragging) so I pulled them off and sent them in for rebuilding. They told me One side was seized and needed a new piston. Got them back on and the same issue is happening, the drivers side is stuck. Even with the brake line OFF this side is hung up, like the pistons are not releasing pressure and holding the brake on.
Before going with fronts, I used a Bus master cylinder and it worked fine.
After putting the front brakes on I went to a dual circuit master and the brakes are Very mushy, after bleeding two quarts of fluid through the system they still are mushy. Put a 2 lb. residual valve on the rear circuit and it did nothing.
If I pump the brakes I get a little more pedal.
I,m thinking I need to go with a CNC master cylinder, maybe ****-can these Jamar rears and get the RLR wide 5 rears or the CNC rears.
Two Questions:
Anyone have any similar experience or any suggestions?
Will two piston rears be sufficient or will I need 4 piston rears?
Two Questions:
