It's taken me a while to get my little project this far, but I have finally arrived at the fun parts. It started out as a 74 Ghia with a rusted pan and no engine for $700. I hauled it back to a single car garage on an AF Base in Ohio and started in on things. Mostly wanted to avoid my first wife and relive some fond memories of my step dad in California fixing up his cars. He owned a VW shop, so I grew up with these cars. Ghia's look a bit more sporty, but that's about all. I wanted to make the car corner and brake as much as I wanted it to go fast. Making it light for road racing was always the goal. I couldn't rely on VW parts for this, so I ordered a 1914cc DRD Racing Heads Stage 2 motor, RLR tube chassis, and Lester Chatley transaxle. I then went to a salvage yard to grab Mazda Miata suspension (double wishbone) and bought many racing bits to round it out. The RLR chassis wouldn't work as it was designed, so I bought a mandrel bender and more tube to customized structural points for my suspension and general layout. I then built a steel square-tube welding table and built the car on that to keep things true. The body was always meant to be removable, so I built a hoist system to pull the body with a push of a button. The front end is removable and tilts on a complex hinge with an electric actuator. I'm now working on the body for paint and trying to add plastic covers to the chassis around the suspension to block rocks and debris. It won't be weather tight, but that's ok for the track and fair weather cruising on the street. I'm adding an O2 sensor now to start tuning the motor and playing with coil springs to get the suspension tuned better. Should have it out next year to play with in autocross and drive it around more. It's getting to be more exciting as it becomes more reliable. I hope you guys enjoy the few pics below. I'll add more info on the engine and chassis tuning as I learn more how to do those things. Might even ask for help!
I did all the work myself as a learning exercise, so be gentle with comments. I'm not a professional car builder. Just wanted something to do.
Body hovering over chassis. Very handy for chassis tuning and maintenance.
Rear view showing custom tail light bulb holders. Couldn't source factory units. Had to clearance the body a lot to fit over tube chassis.
Here is the body with track trim. Homemade large splitter and rear adjustable spoiler. Will make smaller street splitter and remove spoiler for the road.
Will drill more holes in spoiler mounts to adjust angle. Need to experiment on this more.
Chassis is self contained. Just need to add temporary lighting for the road and license plate mount if I want to drive it like this. The body only keeps the bugs off and carries lights. Quick disconnect wire harnesses make things easy to remove the body and front end.
Made some ABS plastic frame covers and installed recently. Working on the rear suspension covers now. The sway bars are from Currie Enterprises and meant for 4x4's. Worked with their Engineers on torsion bar spring rates for my light chassis and low roll center. Still need to lean it into some high speed corners to make adjustments.
