Nick, if you have any questions give me a call at the shop 623 376 2562
does IRS and swing require the same spring plate angle?Austin Larsen said:What's the spring plate angle at ride height
x3Brian Sanders said:Since no one is speaking up I'll pipe in.
From My view it launched like it had street tires.
I say try 12 lbs tire pressure.
Also what clutch disk are you running? It hit pretty hard. You might want to think about CM
or the REV 6
18psi in the tires? Holy Basketballs Batman. What size MT? 8x26? Try something in the 9-10psi range. We always ran about 8.5 in the lighter cars.Nick Wharton said:SO..... wheel hop MAJOR off the starting line. Here's what I got
30mm bars, IRS, `16 way adjustable shocks, dual adjustable. I set them at 8 and 8, and the front single adjustable at 8
I have no video, but the car shook violently enough that a fender dzus popped out.
it still managed a 1.68 60ft. which surprised me
18LBS of tire pressure. Im thinking that the rebound needs to be tightened ALOT
I was happy to have made a pass considering the pressure I had on others to help me.realfastbug said:Is there an advantage to sub 10psi over 15-17psi if you hook with with the higher numbers? Just felt more stable to me but maybe I'm missing out.
I'm just happy for nick that he can go have some fun racing again!
I was Leary of lower pressures too. I was running my tires at 15lbs. ( so I thought)realfastbug said:Is there an advantage to sub 10psi over 15-17psi if you hook with with the higher numbers? Just felt more stable to me but maybe I'm missing out.
