1 - 3 of 3 Posts
Hi every one
Im building a 2275 bug motor
78crank 94 pistons 44 dual empis
120 angle cam
stage one heads everithing new
Need help with nitrous as i want a small shot may be 35 to 50 hp
What kit shoul i buy ?
is it posible with only 2 nozzles?
Thanks
Hi Pedro. If you do a lil search on the site its prob been talked about a few times. Theres another thread recently talking about putting a kit together. I am not sure if you mean only 2 fogger nozzles? or what exactly your referring to. The typical kit uses a fogger in each port so a total of 4 would be used to keep jetting in check.
Maybe a quick search and review can lead to more questions we can all help on....
Nitrous
Ok so its got to have 4 foggers nozzles
Is there a kit that includes a rpm switch pedal switch And 4 nozzles
Can you guys tell me which kit you guys bought so i can have an idea
Were do you guys tap the intakes ?
Why are you guys using gasoline also on foggers ?
Thanks
1 - 3 of 3 Posts
