home from the BUG RUN CLASSIC ,problems with the crank trigger spoiled the day,this is the second time the system just shut down and the car wont start the msd tell us that the trigger signal is lost,checking all cables and contacts everytinge is OK, the system will only 1-2 times off 10 get the signale and wen the engine is running its running bad,a switch's to another trigger did not worked problem still there so we are son running out off ideas but this is racing we will fix it and go racing :th_DragRacer:
