1 - 9 of 9 Posts
u guys have been very helpfull in my set up questions now if any one familiar with sand dragin can help me queston is can i spray right out the hole system has no electronics old school throtle switch and pray i only run 1st and 2nd in a 100yds trans is type 1 good axles threaded super diff 412 ring and pinnion any suggestions would b great or if any other info is needed just ask thanks
Just have a switch so that it will go off when your full throttle and after that it is either go or blow LOL
ok so as long as throttle switch is.set to full throttle arm it dump.clutch.and.let.her.have it and pray lol thanks for all ur guys help maybe i could get a ultimate air cooled sticker if it holds up to ur guys rep
We ALWAYS launched on the bottle....
started out using a button on the steering wheel and after going to EFI, let the unit trigger the hit.
My memory is not too good but as I remember Kris used the Staging brake switch to trigger the bottle.
Let go of the staging brake and the Go Juice was ON!
If your just running it through the WOT switch and nothing else,I would recommend putting a switch on the clutch so that the nitrous won't come on until the clutch is released. You sure don't want it coming on while your on the 2 step.
You might wanna try small does at first.. a hard hit on paddles can break stuff just as easy...
Discussion Starter #9
ok cool.pray.then spray and pick up parts lol im startin with a 50 shot hopefully small.enough but make a difference and also how would u recomend puttin switch on clutch pedal thanks u.guys r a great help and have a safe happy new year
1 - 9 of 9 Posts
