Looking for how you plumbed this combo? About to start building my engine, ready for TT Pink to go fast! My setup will be street driven and running a fan shroud and stock oil cooler.
Thanks!
Lester
i used the a/c pickup tube on the bottom of the sump. went from that to the pump then filter, etc. get rid of the stock pickup deal inside the case so the oil flows freely to the bottom. for the half stage, i just scavenged off the heads.
Did you run the bypass back to the sump? I'm also running turbo and wondering if I can use the scavenge for turbo drain as well?
your making me think.... been a while since i did it. i think i ran it back to the sump. put a bung on the sump and plumbed it to there...
if your turbo is above the motor just do a -10 back to the case. i would use the scavenge for the head(s). not sure if the pump would suck the turbo dry and ruin it.
