Yes, it is possible.. But it will take a big motor for torque.. Let's say you had a 3300 pound F body with a .060 over 455 and some good heads.. so you are at about 7 pounds a cubic inch.. That combo with a decent build should produce mid 11's easy .. Now let's look at VW .. to get to a 7 pounds a cube deal we need , uh.. won't work.. the largest 94 bore you can reasonably build would be a HUGE stroker 2442 cc .. about 149 cube so.. figuring a street bug weight of around 1750 with driver.. divided by 149 cubes you are at close to 12 pounds a cube.. Yes, a streetable bug can run an 11 but it will take more cam, more carb, more gearing and on killosity than your Poncho did.. A bug is a great sixty footer.. and you can hole shot a lot of cars on the street.. A TRUE 200 HP bug with a good close ratio box should be a 11.60-11.75 car..And thrill you like a 9 second V8 car I have seen seen a few 10 second street bugs.. but they are very high maintenance with very few street miles.. If you build a 11 second bug, don't think Power Tour .. ..You can build a streetable 200 horse bug.. get some good heads, and a GOOD gearbox.. decent cars are for sale now and then.. what you get is directly related to what you pay.. but if you are flexible on the car, just want a solid car, then you can find 'em.. Might think about EFI at that point. But carbs are a bafflement to a lotta younger folk... For a 40-50 year old car the VW is still reasonably affordable. Perhaps a cookie cutter 2276-2332 with a little less cam, compression and PM with a tickle of nitrous may suit you.. Do a search here of various combos, and see what is possible.. Good Luck! Remember, a street bug with gears at 1750 pounds and 175 HP is going to be quicker than a 3500 pound V8 with twice the power of the bug.. Bugs just launch so nice.
