Hello all! I'm not very good at introducing myself so I thought it would be easier with a post of myself and my wifes racecar we are in the process of building! ;D
It is as the title says a 1959 UK RHD car so basically it was full of the dreaded rot! It needed the bottom 6" replacing plus lots of other sections too. As its a UK RHD its pretty rare hence why we decided to save it rather than it going to the breakers yard. We also started a blog which has lots and lots of photo's from the start of the project all the way through to current progress..
http://stripteaseracing.blogspot.com
Ok so this is how the car came into our hands
and we drove around like this for a while until the time came to re-build it
You can see here some of the rust we had to contend with
Work started.. (for more pics like this check the blog)
http://i227.photobucket.com/albums/dd37/StripTeaseRacing/59RHD/john_resto7.jpg[/url]
[img]http://2.bp.blogspot.com/__9TZlAt1xCQ/R53h1-XbxBI/AAAAAAAAAMQ/Sizf9OO3ePc/s1600/cross_member_removed.jpg
The welding all complete and a shot of the back which has been cut away..
Some of the parts we started to buy
Aeromotive fuel pump and regulator with carbon fibre pressure gauge! Expensive but soooooo nice!
Painless fuse box to start our wiring from
Master cut-off switch and billet switch handle, switch panel which mounts to the roll cage and will house switches for fuel pump, ignition and starter and a Intercomp tyre pressue gauge. The pressure gauge also glows in the dark so if we run at night we can see the dial! ;D
And the la pièce de résistance - Weld Aluma Star front wheels! 3.5" wide in Chevy pattern PCD.
We also ordered a custom built 2332cc motor from Pat at CB Performance, to say we were pleased with the outcome was an understatement!! It dyno'd at just under 240hp with cooling and Pat was an absolute pleasure to deal with! SOme of you may have seen the motor being displayed at Bug-In 33
I should also explain that I went to Pat asking for a 11 second motor that can run on the street and basically let him roll with it.. I would highly recommend Pat and the guys at CB ;D
Next post to follow with more pictures! (Thanks for reading!)
